Broken front USB
Solved by YoungBlade,
1 minute ago, Manc said:No, the motherboard I bought, the 19 pin USB connector on the motherboard is broken, So i'm looking for an adaptor to plug the front USB connector into a different USB header on the motherboard,
Okay, I see the edit to your post.
Yes, that connector you found should work, and still give you full USB 3.0 speeds.
That is a Type C to USB 3.0 adapter. A "Gen 1 connector" would look very different. It would be for hooking up USB 1.0/1.1, and would be compatible with the USB 2.0 headers on the board.
