Graphics interface running way lower than expected.
Solved by Fetalbrute,
10 hours ago, Eigenvektor said:PCIe 3.0 vs 4.0 makes little to no difference for most GPUs.
The GPUs that are most affected are the ones with only 4 lanes (e.g. RX 6500 XT).
That said, since you are currently limited to 4 lanes that would be something to look into.
Check the motherboard's specs. Could be CPU related, but lanes might also be shared with storage
I checked BIOS and realized that auto mode was setting my pcie to raid mode, making it run at x4, chose to use x8/x8 mode and worked fine, i remembered this motherboard/cpu apparently doesn't like auto mode for things
