Budget (including currency): $700 or less
Country: USA
Games, programs or workloads that it will be used for: No gaming. CPU-heavy work - multi-tasking with live video chat, stylus and drawing pad, whiteboard app, pdf reader, browser, etc. Nothing crazy, just ought to be reliable
Current part list: https://pcpartpicker.com/list/khvYGJ
This is for a relative who runs a tutoring business.
Specific asks:
  • Keep it small. I chose ITX form factor for that.
  • Keep integrated graphics, unless you think there's a compelling reason to switch for this use case
  • Suggestions to save $$ would be particularly welcome
    • I'd love to save some overhead on the CPU, but I'm not confident enough in comparing CPUs to pare it down.
  • Dual monitors, webcam, other peripherals already owned
  • Windows license needed; included in list.
  • ASAP purchase. Current laptop is inadequate.
No matter what, anything would be a massive upgrade. She's currently scraping by on a Pentium N6000 (with 40GB of RAM??!!?!? - I have no logical explanation for this but open to hear ideas).
Thank you all!
https://linustechtips.com/topic/1619425-new-build-for-work/
I'd also suggest considering mini-pcs, like a minisforum UM790 Pro or even a mac mini. The UM790 Pro seem great for the aforementioned use case, it's 400$ for the barebones model, comes with an 8 core ryzen 9 7940HS with solid integrated graphics with support for up to 4 displays, 2xHDMI and 2 through the USB 4 ports, 2 SSD slots and 2 sodimm memory slots which you'll need to buy memory and storage at additional cost since it's a barebones model.
https://linustechtips.com/topic/1619425-new-build-for-work/#findComment-16777525
