i have a 1070 8 gb ram and Processor    Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz, 3192 Mhz, 4 Core(s), 4 Logical Processor(s) with lenovo sky bay motherboard the build is shit. but its kinda old so i was thinking to upgrade to a i7 6700K and 16bg ram or 32 gb ram is that a good choice
https://linustechtips.com/topic/1618588-i-need-help/
Welcome to the Forums!
Whether or not this is a good choice is going to depend on the pricing of the parts in your region. The i7 6700K is slower than even low-end parts today, so you'd want to get it for a very low price compared to getting new hardware to have it make sense.
https://linustechtips.com/topic/1618588-i-need-help/#findComment-16772116
I'd probably grab a new CPU/mobo/RAM setup, along with a PSU and case and SSD...
Nm, just save up for a new machine.  Bring the 1070 over as a placeholder until you can afford a GPU.
Was this a prebuilt?   Regardless, the CPU is 10 years old and anything that fits that mobo will be 9-10 years old and perform just as poorly in todays usages.
Basically, if what you have doesn't cut it... nothing you can "upgrade" to will either.
UNless you want to throw another 8GB RAM in and move to a SATA SSD (assuming you only have harddrives).
That's about all I would recommend throwing at your current build.  Sorry.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1618588-i-need-help/#findComment-16772117
The CPU cost about 50 dolalr
The CPU costs 50$
https://linustechtips.com/topic/1618588-i-need-help/#findComment-16772122
The CPU costs 50$
Get it, sell your 6500 for a few bucks to offset.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1618588-i-need-help/#findComment-16772125
1 minute ago, AbuYusuf1123 said:
Ok so should I get a 30 GB ram or a 16 GB ram
Just 16GB.  Add another kit or stick of 8GB, matching what you have.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1618588-i-need-help/#findComment-16772134
Ok Ty bro. I wonder will it run games good/ok with low graphics preset like god of war, cyberpunk and red dead redemption
Should meet Cyberpunk's minimum specs...
To play Cyberpunk 2077, you need the following system requirements:
  • Minimum Requirements:
  • OS: 64-bit Windows 10
  • Processor: Intel Core i7-6700 or AMD Ryzen 5 1600
  • Graphics Card: NVIDIA GeForce GTX 1060 (6GB) or AMD Radeon RX 580 (8GB)
  • RAM: 12 GB
  • Storage: 70 GB available space.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1618588-i-need-help/#findComment-16772136
  • RAM: 12 GB
I could buy a ryzen 5 5600x If my mother board is compatible with it skyebay lenovo
https://linustechtips.com/topic/1618588-i-need-help/#findComment-16772142
It's not.  Your motherboard can only use that generation of CPUs that the 6500 and 6700k are part of.
The absolute best CPU your motherboard can run is the 6700K.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1618588-i-need-help/#findComment-16772143
7 minutes ago, AbuYusuf1123 said:
Would u recommend another CPU instead of the i7 6700K
If it's cheaper, you could get the regular i7 6700, without the K ending. They're very similar in performance.
Otherwise, you'd need to do a complete upgrade to a new system.
https://linustechtips.com/topic/1618588-i-need-help/#findComment-16772147
Upgrading your current system is mostly going to be a waste of money, I'd save your money and look for a more modern second hand system or parts.  realistically any 6th gen cpu is obsolete as its 10 years old. Adding a newer GPU wouldn't work as it would bottleneck and upgrading the cpu using the same motherboard will only give you a small improvement in games. I'd look into getting a new motherboard + cpu + ram as a starting point, then get a new GPU and potentially a new PSU (your old one might not be enough to power a new gpu+cpu combo)  when you have enough money
https://linustechtips.com/topic/1618588-i-need-help/#findComment-16772149
