51 minutes ago, Xymorm said:
i was wondering if there was a quick guide to set up a mining program and if there are any recommendations on which program to use?
As a matter of fact, there is indeed a very simple guide. It goes as follows:
"Don't."
That's it. Don't mine. Period. It's not profitable without free power, but even if you do have it, you're still better off dedicating that electricity for something actually useful like Folding / BOINC instead of throwing it away for naught.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/1618509-questions-on-mining/#findComment-16771591
@Imakuni Perfectly explained what to do!
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1618509-questions-on-mining/#findComment-16771623
At the moment, mining is not profitable unless you have dirt cheap electricity.
If your electricity is free, or super cheap like 5¢ per kWh, then you might be able to earn some money, but it depends on the hardware you have. If it's not recent, like from the last 5 years, odds are, it won't be able to make you anything.
What is your electricity situation like? And what hardware do you have to work with?
https://linustechtips.com/topic/1618509-questions-on-mining/#findComment-16772209
1. Do you have a few of A1000 and a direct connection to the power plant?
If the answer is 'No' - join the flow and buy/trade crypto. This is the only way a private person can earn crypto tokens these days.
*using non-conversational, sketch-level language to gesture at structure and direction.
The GB8/12 Liberation Front
https://linustechtips.com/topic/1618509-questions-on-mining/#findComment-16772898
