Hard Resetting - Kernel Power
1 hour ago, mrtherm said:Here we go,
A fatal hardware error has occurred.
Reported by component: Processor Core
Error Source: Machine Check Exception
Error Type: Cache Hierarchy Error
Processor APIC ID: 7 (and a 6 some of them)
The info in the general tab is what reported the error, not what caused the error. To see what caused the error you have to decode the error packet in the RawData fields using the UEFI documentation.
The CPU is ordering the shutdowns. These show up as "Previous Error", meaning it's not from the actual error, just a notification that it shut down the PC from the previous error. We can't see the original error with these issues. 90% of the time it's the CPU, but it can also be a PCIe device or even the motherboard is the CPU/PCIe section is faulty.
We have seen a lot of voltage issues on 5000 series so we could try setting a static voltage which has fixed a lot of 5900x and 5950x CPUs that have had lots of different CPU related crashes. In the BIOS, set a static voltage to the CPU of 1.3v and to the SoC set a static voltage of 1.1v (CPU Vcore and VCORE SOC on this motherboard).
