Budget (including currency): 1800-2000$ CAD (Canadian)
Country: Canada
Games, programs or workloads that it will be used for: Primary: Gaming (Apex Legends, Cyberpunk 2077, Red Dead Redemption, Dead by Daylight, Marvel's Rivals, Minecraft with shaders)
Wanted Resolution: 1440P Or 4K (I'm completely fine with 1440P though)
Secondary: Video editing (Adobe Premiere Pro, CapCut), school work, everyday use
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):
Hello! This is my first ever pc and pc build. And I decided to build it after failing to find a decent deal on a prebuilt. I made a build myself on PcPartPicker and I wanted your guys input before I spend 2000$ on the parts. let me know if it’s solid or potentially any improvements I could make.
too add more context:
It’s costs 2000-2100$ CAD after tax.
here’s the build:
https://ca.pcpartpicker.com/list/MpFsfd
Heres the build In text:
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor
$490 (bundle) (CPU, Motherboard, Ram)
CPU Cooler: Thermalright Burst Assassin 120 SE ARGB 66.17 CFM CPU Cooler
Price
$32.39
Motherboard (Apart of CPU, motherboard, Ram bundle): Asus PRIME B650M-A AX6 II Micro ATX AM5 Motherboard
Bundle cost : $490
Memory: TEAMGROUP T-Force Vulcan 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Apart of CPU, motherboard, Ram bundle)
Bundle cost: 490$
Storage. KingSpec XG7000 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Price
146$
Video Card: Gigabyte GAMING OC Radeon RX 9070 XT 16 GB Video Card
Price
$950
Case: Thermaltake View 170 ARGB MicroATX Mini Tower Case
Price
85$
Power supply: Cooler Master MWE GOLD 750 V2 FULL MODULAR 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Price
110$
I’m buying this bundle with it (that’s why the board is a bit weak): https://www.memoryexpress.com/Products/BDL_MM00004810
but I also found another bundle expect a different motherboard: https://www.canadacomputers.com/en/amd-desktop-processors/272958/amd-r5-7600x-cpu-gigabyte-b650m-gaming-plus-wifi-motherboard-t-force-32gb-d5-6000mhz-ram.html
let me know which of the two bundles I should get, or any improvements I could make. Any help will be appreciated!
https://linustechtips.com/topic/1614519-first-ever-build-need-help/
Country: Canada
here’s the build:
Price
$32.39
Bundle cost : $490
Bundle cost: 490$
Price
146$
Price
$950
Price
85$
Price
110$
if the cpu cooler isn't apart of the bundle(my internets funky right now so I can't open the page) I would get the Thermalright Peerless assassin 120 se or the phantom spirit version
(try and keep it to one thread)
