Country: Korea
Games, programs or workloads that it will be used for: gaming + simple web-based work + some graphics design
CPU: AMD ryzen5 7500F
Mboard: MSI Pro B650M-A WIFI
Memory: Patriot DDR5-6000 CL30 16Gx2
Cooler: Thermalight Aqua Elite 360 ARGB V3
SSD: Essencore Klevv Cras C910 M.2 NVMe 1TB
Power: Maxelite Maxwell Count 750W 80+ Gold Fullmodular (don't know if this is good because I can't find it in the psu tier list)
Case: Montech Air 1000 Premium
GPU: ?
This is my current PC parts list, and I’d like some advice on which GPU I should look for. I’m aiming for a minimum of 12GB of VRAM.
If you notice any issues with the rest of my PC parts list, please let me know. Keep in mind that I’m not building this computer in the U.S., so performance-per-cost expectations might differ compared to a U.S. based build.
Thanks for checking out my post!
https://linustechtips.com/topic/1614110-help-with-pc-list-gpu/
What software?
What (monitor) resolution and type of games do you play?
Budget?
https://linustechtips.com/topic/1614110-help-with-pc-list-gpu/#findComment-16742313
5 minutes ago, poppyplaytimepc said:
Country: Korea
GPU: ?
Everything works other than the psu which I've never heard of before now. Your choice of gpu depends on your resolution and budget.
https://linustechtips.com/topic/1614110-help-with-pc-list-gpu/#findComment-16742314
14 minutes ago, poppyplaytimepc said:
Country: Korea
GPU: ?
Maybe Arc B580 12gb for $300 or an RX 9060 XT 16gb or 5060ti 16gb
https://linustechtips.com/topic/1614110-help-with-pc-list-gpu/#findComment-16742320
7 minutes ago, poppyplaytimepc said:
Blender.
From the benchmarks I've seen, nvidia works best with blender (and by a wide margin).
Not sure about Intel cards.
I hope to get 1440p. Budget would be around 1200$.
For that budget: I'd look at the 5070 Ti or 5080. 5080 is around 15% faster.
You can get away with a lot less, e.g. 5060 Ti 16GB, but since you have the money,...
https://linustechtips.com/topic/1614110-help-with-pc-list-gpu/#findComment-16742321
17 minutes ago, poppyplaytimepc said:
Country: Korea
GPU: ?
you can use a peerless assassin 120 se instead of the aio to save some money, and the MSI mag a750gl is a good psu.
https://linustechtips.com/topic/1614110-help-with-pc-list-gpu/#findComment-16742322
about 600 dollars
5060 Ti 16GB or 5070 is within your budget. If still available: 4070/4070 Super, or maybe a 4070 Ti.
4070 Ti Super 16GB or 5070 Ti would be the best, but a lucky find for 600 dollars.
https://linustechtips.com/topic/1614110-help-with-pc-list-gpu/#findComment-16742353
1 hour ago, poppyplaytimepc said:
Blender. I hope to get 1440p. Budget would be around 1200$.
Then maybe a 9070XT or RTX 5070ti/5080
https://linustechtips.com/topic/1614110-help-with-pc-list-gpu/#findComment-16742401
