Need Help Deciding on Upgrades
Solved by Tetras,
4 minutes ago, KyberMike said:@Tetras okay, didn't realize that with the b580, so thanks!
all the low-profile cards i've seen are either way out of my price range (4060 and 5060 are both $480+) or significantly underpowered (3050 6gb, rx 6400 4gb) compared to the 8gb rx 6600.
I was thinking of something more like a 1050 or 1650. They're not great and unsuitable for most AAA games, but should be WAY better than what you have.
