Bios/bsod/windows install help
Go to solution Solved by BillBill,
17 minutes ago, Gunboss99 said:
Hello! I recently built my first computer, MSI 5090 Trio ASUS Z790-PLUS WIFI Intel core i9 14900 2x 4 tb Samsung ssd G skill ripsaw s5 memory (32 gb) All new parts
And no real major issues with parts/assembly until I tried to put Window 11 on it. I was able to install windows (I think) but when attempting to boot from the ssd, it will just send me back to the bios screen. I am unable to reinstall windows as the drive is already partitioned, and attempting to repair windows provides this. The computer does not restart as well, at least on its own.
I have attempted to try and run it with any unessential components(window install usb etc) and reseating all components. I have also tried to restart cmos, which successfully completed, but changed nothing.
Any ideas would be appreciated, my only thought would be to wipe the drives, and do a fresh install, but I am unable to do it.
Turn off the PC. Insert the USB flash drive with the Windows installer on it. Make sure it is in a USB 2.0 port. Turn the PC on and tap the F12 key. There you can select the boot menu. Select the USB flash drive. You should be able to remake the partitions.
https://linustechtips.com/topic/1613914-biosbsodwindows-install-help/
