FX-6300 Stuttering / Dropping frames randomly
Solved by Chris_nz,
I see, I have Had this problem before with a MSIR7770 Playing the witcher 2, finally got sorted with a driver update, but it was still noticeable
I would suggested to see if you have the latest drivers ( pretty sure you would ) also try overclocking the gpu slightly, it helped me in someway with my old card, try use MSI afterburner and increase the power limit to 20+
Good Luck ^^
