Help with security DVR
Solved by Agall,
1 hour ago, NachoKingP said:I've got a new security system DVR and it didn't come with an internal drive. I went to move the old system internal drive over and the power connectors are different, and trying to find an adapter is driving me crazy. The old one is standard Molex, the new one is 4 pin, but they're larger than I've seen. Attached photos for reference. Help?
It would be worth checking some technical documents for that unit, the 4 pin might just be the same pinout as a molex but using a more compact motherboard header.
I'd recommend adding what model this unit is to let us better figure this out.
