Hello! I want to add more argb (Arctic P12 3 pack) fans to my pc, but my motherboard (Gigabyte B650 Gaming X AX V2) doesn't have any free argb headers. I've thought about just daisy chaning the fans through my AIO fans (Arctic liquid freezer III 360mm), but I've read that it only supports 5 fans. The dilemma I'm facing is that when it means 5 fans, does that mean power 5 fans, and not to power the rgb? Because I have free fan headers. Or should I look into buying a fan hub? Also I've checked, if I can put 2 140mm instead, but my case can't fit it.
Full pc list if interested: https://se.pcpartpicker.com/list/zNd6vj
https://linustechtips.com/topic/1608618-no-availableargb-headers/
try an RGB controller hub
I AM HUMAN AND I MAKE MISTAKES. FACT CHECK IMPORTANT INFO!
Laptop: Lenovo Thinkpad T450. Desktop CPU: Ryzen 5 8500G, RAM:G.Skill Flare x5 32GB(2X 16GB), MoBo: ASUS PRIME B650M-A WIFI, Case: Inland X1, GPU: ASRock RX 6500 XT 8GB
1 hour ago, BanSoda said:
Which one should I get? I don't want the arctic one because, it's not software adjustable
i dont like corsair but their commander worked pretty well in a build i did for the kiddo a couple years back...
Corsair has a few models that are pretty good.
by RGB controller hub, i mean just the hub, not the whole panel.
I got a simple Thermalright fan+aRGB hub, works nice
oh, lol , got it, the the thermalright is pretty good, ive had luck with that and the microcenter brand that starts with an s.... , i mean you could do some realllllllly cool things with that overkill stage controllor tho...  who cares about price /s, rgbs worth its weight in gold
