Hey, decade old viewer, first time post.
Here is my current, rig.
https://pcpartpicker.com/list/TJHZjn
The GPU stimmer is a V2 non wireless. I bypassed the extension I don't trust, stripped the strim and fastned/added it to stock GPU wire provided with the psu. Total build cost 11kcad with tax.
https://linustechtips.com/topic/1608237-needs-more-rgb-build/
Pretty. Also wonder what the back panel looks like with all the cables. Have you got a picture?
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1608237-needs-more-rgb-build/#findComment-16701380
Arent these Lian Li fans daisy chained (same fans for the AIO from what I see) resulting in less wires??
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
https://linustechtips.com/topic/1608237-needs-more-rgb-build/#findComment-16701381
