CM Storm Quickfire TK LED Issues
Solved by Karumu,
Hi all!
I just bought a CM Storm Quickfire TK with blues, and loving it so far, but for some reason the only keys that light up are the arrow keys and the function key.
I have tried the FN + Brightness Up and Brightness mode, is it faulty?
Thanks in advance!
hold down the function key til it stops lighting up and then press FN+Mode and it should light them all up
