Budget (including currency): 2500€
Country: Finland
Games, programs or workloads that it will be used for: ARPG,MMO,FPS,RTS
Other details
My current build is from 2019. Intel 9900k + 2080TI.
It still runs games, i want to upgrade or wait more?  I want comfortably play at 1440P. Since this is a new build, i really don't want any last gen stuff on it.
https://linustechtips.com/topic/1604503-build-for-2025/
Country: Finland
Other details
PCPartPicker Part List
CPU: AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor (€572.90 @ Multitronic.fi)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler (€37.90 @ Datatronic)
Motherboard: Asus TUF GAMING B850-PLUS WIFI ATX AM5 Motherboard (€239.90 @ Jimm's)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (€106.98 @ Proshop)
Storage: MSI SPATIUM M480 PRO 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€147.90 @ Datatronic)
Video Card: Sapphire PULSE Radeon RX 9070 16 GB Video Card (€709.90 @ Jimm's)
Case: Fractal Design North ATX Mid Tower Case (€164.90 @ Datatronic)
Power Supply: NZXT C850 (2024) 850 W 80+ Gold Certified Fully Modular ATX Power Supply (€149.88 @ Proshop)
Total: €2130.26
Generated by PCPartPicker 2025-03-08 18:18 EET+0200
https://linustechtips.com/topic/1604503-build-for-2025/#findComment-16676218
A board that supports PCIe 5.0 along with a gpu that supports PCIe 5.0.
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (€502.90 @ Multitronic.fi)
CPU Cooler: *Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  (€45.90 @ Jimm's)
Motherboard: *MSI PRO B850-P WIFI ATX AM5 Motherboard  (€205.90 @ Datatronic)
Memory: *Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€97.90 @ Datatronic)
Storage: *Patriot P400 Lite 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€112.90 @ Datatronic)
Video Card: *Asus PRIME OC Radeon RX 9070 XT 16 GB Video Card  (€720.90 @ Datatronic)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  (€68.90 @ Datatronic)
Power Supply: *Asus TUF Gaming 850G 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€112.90 @ Multitronic.fi)
Total: €1868.20
Generated by PCPartPicker 2025-03-08 18:58 EET+0200
https://www.tomshardware.com/software/windows/windows-11-free-or-cheap
A better look at those components.
https://www.msi.com/Motherboard/PRO-B850-P-WIFI
https://www.tomshardware.com/reviews/thermalright-phantom-spirit-120-review
https://www.patriotmemory.com/products/patriot-p400lite-nvme-m2-solid-state-drive
https://www.asus.com/us/motherboards-components/graphics-cards/prime/prime-rx9070xt-o16g/
https://www.asus.com/us/motherboards-components/power-supply-units/tuf-gaming/tuf-gaming-850g/
https://www.montechpc.com/air-903-base
https://www.techpowerup.com/review/montech-air-903-base/
https://linustechtips.com/topic/1604503-build-for-2025/#findComment-16676250
1 hour ago, Tr1kk1 said:
Yes. My problem is more of the CPU and GPU side. I don't know what combo is the best for 1440P.
Look at either the 7800x3D + RX 9070 XT 16GB or if you want the option to use DLSS then look at the 7800x3D + RTX 5070 Ti 16GB.
If you are going to use 2xM.2 SSD's then look a X870 chipset board so that you have enough PCIe lanes (bandwidth).
Motherboard: *Asus TUF GAMING X870-PLUS WIFI ATX AM5 Motherboard  (€299.90 @ Proshop)
Total: €299.90
Generated by PCPartPicker 2025-03-09 09:57 EET+0200
If using 3xM.2 SSD's then you want a X870E chipset board.
Motherboard: *MSI MAG X870E TOMAHAWK WIFI ATX AM5 Motherboard  (€370.90 @ Proshop)
Total: €370.90
Generated by PCPartPicker 2025-03-09 09:59 EET+0200
https://linustechtips.com/topic/1604503-build-for-2025/#findComment-16676729
  • 5 weeks later...
Now i have parts pretty much locked in. CPU pick provides a bit of challenge. Since im buying these parts from a single store and not where it is necessarily the cheapest. 9800X3D is 599,99€ and the 7800X3D is 479,99€. Is the 9800X3D worth the extra money?
https://linustechtips.com/topic/1604503-build-for-2025/#findComment-16701282
https://www.techpowerup.com/review/amd-ryzen-7-9800x3d/19.html
https://linustechtips.com/topic/1604503-build-for-2025/#findComment-16701298
