Budget (including currency): ~$2,200 with the 4080 super
Country: US
Games, programs or workloads that it will be used for: cyberpunk 2077, fortnite, single player games, open world games
https://pcpartpicker.com/user/is7cr797/saved/R4cMwP
What are your thoughts for this build? What could I do better? Also I plan on getting the 5080. If I'm not able to purchase one, I will keep the 4080 super. I keep having people telling me not to overspend on a motherboard, and then others saying the cheap motherboards are terrible, and then people saying all b650 motherboards are the same for gaming. So this sort of has me confused as a beginner to pc building. All I know is that I would at least like to have WiFi 6E, and for it to be able to deal with the 9800x3d and also possibly the 5080. I don't at all understand the PCIe 5 and 4 stuff, I hear reviewers docking points for motherboards not being PCIe 5 but then others saying you definitely don't need it.
https://linustechtips.com/topic/1595150-first-build-help/
Country: US
This is a decent build indeed.
I would like to see a better motherboard, you don't have to go crazy with price either.
A full ATX motherboard will also look better in the case.
I am seeing a white theme as well so a white motherboard would be cool but that would increase the price.
A Gigabyte B650 EAGLE AX - MSI B650 GAMING PLUS WIFI are nice boards without breaking the bank.
https://linustechtips.com/topic/1595150-first-build-help/#findComment-16614957
Do you think I should wait for the Eagle AX to go down to 140? It looks like it was at 140 a month ago? Or will motherboards will go up in price when the new gpus come out?
https://linustechtips.com/topic/1595150-first-build-help/#findComment-16615010
Its up to you.  Motherboard pricing has little to do with new GPU's coming out.
You can probably find a deal at some point or you can buy it now, 20 bucks is not really that much difference ( considering the price of all the other parts )
https://linustechtips.com/topic/1595150-first-build-help/#findComment-16615015
Cool I guess it’s not that much of a difference, thank you so much for your time, I appreciate it🙏🏽
https://linustechtips.com/topic/1595150-first-build-help/#findComment-16615122
