I have a cheap Redragon keyboard and when gaming (RDR2 etc) if I push shift to sprint it will toggle sprint until i stop it or if I push Ctrl to stop it will stay stopped until i push Ctrl again
Pretty sure It never used to do this so im not sure if its a software or hardware problem
Any suggestions?
https://linustechtips.com/topic/1591290-keyboard-problem/
Any suggestions?
Maybe you have some of those stupid windows settings turned on like a sticky key?(sorry for bad English)
https://linustechtips.com/topic/1591290-keyboard-problem/#findComment-16589231
I would say your English is like 99% good here, The only "issue" is it's called "sticky keys" but we all know what you mean
I agree, it is either sticky keys or game settings, rather than being the keyboard, at least that would be my guess
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1591290-keyboard-problem/#findComment-16589247
I agree, it is either stickly keys or game settings, rather than being the keyboard, at least that would be my guess
Thx for correcting me. I had an issue with my keyboard some time ago (CTRL button was always on) but the solution was new cable, old one was broken
https://linustechtips.com/topic/1591290-keyboard-problem/#findComment-16589253
Also possibly just an in game setting for sprint toggle and whatever you have ctrl bound to, crouch/slow walk toggle?
Change from toggle to run to hold to run
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1591290-keyboard-problem/#findComment-16589260
No worries, I hope I did it respectfully, I'm learning Spanish atm, Getting feedback from natives is very valuable for me
https://linustechtips.com/topic/1591290-keyboard-problem/#findComment-16589262
God, I had forgotten about that crap.  Used to be very annoying in Windows 7, like in the middle of gaming you get
a window pop up about sticky keys...luckily haven't seen it in windows 11.
I do keep getting on startup: would you like to finish setting up windows now?
Still looking for the "Piss Off" option on that...
https://linustechtips.com/topic/1591290-keyboard-problem/#findComment-16589646
