Need some advice on storage
By
rkronx
in Storage Devices
in Storage Devices
Solved by Aleph256,
59 minutes ago, rkronx said:Or should I install only the blank 500GB SSD first, set up Windows, and then open up my computer to install the other two drives?
This. Make sure the only software installed on the other two drives is the kind wher you can specify to look for an existing install.
errorcode123_dindin1 ·
Posted in Graphics Cards2 -
Packhunter ·
Posted in Graphics Cards1 -
11
2
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies3 -
Airmack ·
Kyle89 ·
Posted in Troubleshooting2 -
8
5
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
