Help Required with PC Building
1 hour ago, Dedayog said:The bundles are for the CPU, motherboard, and RAM. You need the remaining pieces, including a CPU Cooler.
You buy this list from the vendors listed:
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler ($35.90 @ Amazon)
Storage: TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($102.59 @ Amazon)
Video Card: ASRock Challenger OC Radeon RX 7900 GRE 16 GB Video Card ($529.99 @ Newegg)
Case: Montech AIR 903 MAX ATX Mid Tower Case ($69.90 @ Newegg)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($84.99 @ Newegg)
Monitor: Gigabyte M27Q 27.0" 2560 x 1440 170 Hz Monitor ($179.99 @ Amazon)
Total: $1003.36
Generated by PCPartPicker 2024-11-22 18:41 EST-0500
And get one of these bundles from MC...
Main list of bundles:
https://www.microcenter.com/site/content/bundle-and-save.aspx
9700X bundle $429...
7600X3D bundle $399...
Note: The 9700X is arguably a better CPU than the 7600X3D for more than gaming.
Okay, thank you! Is there any chance anything on the list will be a bit cheaper closer to Black Friday? Just curious ^^
Also, is there any bundle worth getting more than the other given what I want to achieve? The games I currently have right now probably don’t require much to run, and I probably won’t invest much time and money into bigger games such as MMORPGS for a while since I’ll still be busy with my studies.
