Pc building
Go to solution Solved by Trembletop,
https://fr.pcpartpicker.com/list/
if coding is a big thing you might want to consider a 3060 but its worse then a 6650 XT for gaming.
Prices may vary since this list is in France and your in Greece but this build should get you 60 fps on GTA 5 max settings, is shown here
Not the most reliable source but it's all I could find
I couldn't find any benchmarks easily on the 5600x and 6650xt but I did for black ops 6 where they averaged 90 fps on 1080p ultra setting
you can run siege on a toaster oven but here's a video of the 5600x and 6650 XT doing 250 fps on average on siege
Hope this helped!
Budget (including currency): 500-700€ (540-760$)
Country: Greece
Games, programs or workloads that it will be used for: Coding, GTA5, Call of duty black ops 2/3 (possibly more) and if possible Rainbow Six Siege too.
Other details:
Hi, so this is my first time trying to build a pc from scratch, I need some recommendations on parts that i should buy because I know very little about them. I need it to handle the games I mentioned above at 60fps at least, I also need a monitor I don't have that either, anything over 60 fps is fine. I'm also open to purchasing used parts that's fine too as long as it gets me what i need. Thank you!
https://linustechtips.com/topic/1587503-pc-building/
Hope this helped!
https://linustechtips.com/topic/1587503-pc-building/#findComment-16561135
No Greece PCPP and don't know sites, so I'll use Germany as best reference. Use included CPU cooler:
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (€109.43 @ notebooksbilliger.de)
Motherboard: ASRock B450M PRO4 R2.0 Micro ATX AM4 Motherboard  (€64.90 @ Amazon Deutschland)
Memory: *G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€30.89 @ Computeruniverse)
Storage: *Kingston NV2 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€50.90 @ Alza)
Video Card: ASRock Phantom Gaming D OC Radeon RX 6750 XT 12 GB Video Card  (€340.04 @ Proshop)
Case: Zalman S2 ATX Mid Tower Case  (€39.90 @ Alza)
Power Supply: SeaSonic B12 BC 750 W 80+ Bronze Certified ATX Power Supply  (€62.90 @ Amazon Deutschland)
Total: €698.96
Generated by PCPartPicker 2024-11-01 15:36 CET+0100
And for 57eur more you can get a RX6800 PC. I have that GPU, absolute monster.
That being said, Greece pricing will likely be different and no point penny pinching here like a finalised configuration.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1587503-pc-building/#findComment-16561226
