Help With Dash Cam
Thanks for the input, I ended up getting it working, and what I needed was a wire crimper, I got one at a local store and it works, I previously tried to use plyers and needle nose plyers, and I thought it worked, but I truly couldn't crimp it enough without the specific tool.
So setting it up was actually easy, there are plenty of good tutorials out there that are great to set it up, but non of them truly tell you how the crimp should be, they all say, "you can use plyers if you don't have this random tool nobody ever has". But I had the fuse taps in the right spot and everything else worked, but I didn't have the wire connected to the wire tap crimped hard enough.
Random tip though, if you use chat GPT 4o, send it a picture of your manual and explain what you are doing it will actually tell you good info that is so easy to understand compared to the generic response from the YT videos, can't get more personal then having AI tell you exactly how to do it.
