USB and Bluetooth issue?
Go to solution Solved by FireLegend,
UPDATE: Cables just became loose when installing the GPU.
Hello,
Just upgraded my GPU in my system and when I installed everything it was fine works great but only thing my bluetooth doesn't work. I looked in Device Manager and did find one thing about something called Unknown USB Device and I'm wondering if they're linked. Restarted my PC twice still nothing but not sure where to go from here...
All I really can base it off.
Any help is greatly appreciated!!
https://linustechtips.com/topic/1582699-usb-and-bluetooth-issue/
