Budget (including currency): N/A
Country: UK
Games, programs or workloads that it will be used for: Gaming (mainly)
Hi
I'm going to upgrade my current build as I need the CPU, motherboard and RAM to put into an Unraid server. Current parts are i7-8086K, ASUS Maximus X Hero and 32GB G.Skill DDR4 Trident Z RGB 3600Mhz. The cooler is the NZXT Kraken X62 which I'll be reusing in the new setup (with appropriate mounting bracket).
These are the components I'm thinking of getting to upgrade, just wondering if anyone has any feedback on these parts? Any others I should consider etc?
https://uk.pcpartpicker.com/user/takkischitt/saved/CVY38d
https://linustechtips.com/topic/1581924-pc-upgrade-advice/
10 minutes ago, takkischitt said:
need to share the build link or unprivate the saved list
current PC:
PC configs I used before:
https://linustechtips.com/topic/1581924-pc-upgrade-advice/#findComment-16513840
Country: UK
Hi
That's ok, not sure of the board quality tho, but what is your GPU and monitor resolution? GPU may be a huge bottleneck with a 7800X3D at 1080p on an old/weak GPU
https://linustechtips.com/topic/1581924-pc-upgrade-advice/#findComment-16513849
GPU is a 3080Ti FE. Monitor is LG UltraGear 34GN850 ultrawide (3440 x 1440).
What motherboards are recommended for that CPU these days?
https://linustechtips.com/topic/1581924-pc-upgrade-advice/#findComment-16513859
Some Gigabyte B650 Gaming or Elite
But really all B650 boards are ok with a 7800x3d, look at the connectivity/audio/M2 and PCie slots you need
https://linustechtips.com/topic/1581924-pc-upgrade-advice/#findComment-16513896
No need to be vague, here's like 1500 pounds worth of examples that will work nicely,
https://uk.pcpartpicker.com/list/RNZG7R
current PC:
https://linustechtips.com/topic/1581924-pc-upgrade-advice/#findComment-16513908
Ok let's not be vague at all, everything is here 🙂
https://docs.google.com/spreadsheets/d/1NQHkDEcgDPm34Mns3C93K6SJoBnua-x9O-y_6hv8sPs/edit?usp=sharing
https://linustechtips.com/topic/1581924-pc-upgrade-advice/#findComment-16513913
9 minutes ago, PDifolco said:
I don't even use this
current PC:
https://linustechtips.com/topic/1581924-pc-upgrade-advice/#findComment-16513924
Only way to have all the details at hands about USB ports, M2 and Pcie, lane sharing...Not needed but useful
https://linustechtips.com/topic/1581924-pc-upgrade-advice/#findComment-16513929
