Im wondering about 80+ power supply units. I have a 500 watt Thermaltake PSU non 80+. If im just surfing the web will it be pulling 500 watts (or maybe not that much) out of the wall? Will the 80+ PSU pull less out of the wall then a non 80+ PSU when its not under load? (hope this made sense!)
Thanks,
https://linustechtips.com/topic/15801-80-power-suppl-units/
No it will not be pulling anywhere near that.
That's it's top rated wattage, you'll only see that kind of pull under load if you actually have components that will draw that much.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/15801-80-power-suppl-units/#findComment-177965
I hope you're not talking about a TR2 thermaltake power supply. I've heard really bad reviews about those. If you're system is going to have a high power consumption I would avoid those if you can.
System specs:  CPU: AMD Phenom II x3 705e unlocked to x4 overclocked to 2.8GHz   |   MB: ASUS M5A78L-M LX PLUS   |   Cooler: Hyper 212+   |   GPU: MSI GTX 560ti OC to 910Mhz   |   RAM: 8GB PNY DDR3 1333   |   HDDS: WD Caviar Blue 320GB, Hitachi 500GB HDD   |   PSU: Cooler Master Extreme Power Plus 500W   |   Peripherals: Microsoft wireless mouse, old mac keyboard, ASUS VS238H, Gateway FPD2275W, some speakers, Logitech Driving Force Pro
https://linustechtips.com/topic/15801-80-power-suppl-units/#findComment-177987
No, the 500w measurement on your power supply just refers to the maximum amount of wattage that your power supply can supply.
So when idling, your computer may only be using something like 50 to 100 watts, because that's all the power it needs.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/15801-80-power-suppl-units/#findComment-177994
With 80 plus, at 20% 50% and 100% loads, it is 80% efficeint with converting AC power (outlet power) to DC power (power usable for computer components. This means that if you have an 80 plus power supply, it will make better use of less electricity than the non-80 plus. Linus did a video on this, and I will put it in this response.
http://www.youtube.com/watch?v=dOXTZizoknc
Hope that helped!
- winny3141 :D
System Specs: AMD Phenom II X6 1100T Six-core CPU, AMD Radeon HD 6970 2 GB GDDR5 16X PCIe Video Card, MSI 890FXA-GD70 Motherboard, Kingston Hyper-X 1600 MHz RAM, ADATA 128 GB MLC SSD, 2 TB HDD, Astec Dual 120 mm closed Liquid cooling Loop, Cooler Master 800W Silent Pro Gold (80 Plus Gold Certified) PSU, Razer Black Widow Ultimate 2013 Gaming Keyboard (Love me my Cherry MX Blue Switches), a Razer Taipan Gaming Mouse (8200 dpi 4G sensor FTW!), Windows 7 Ultimate 64-bit
https://linustechtips.com/topic/15801-80-power-suppl-units/#findComment-178051
Yea well I actually am using the 500 watt TR2 power supply... and with a Radeon 7850 its almost maxed out. sooooo I guess ill start looking at another one. It was the only one I could afford at the time but i plan on getting a higher watt psu anyway.
https://linustechtips.com/topic/15801-80-power-suppl-units/#findComment-192306
