Problems with new build
Go to solution Solved by Tetras,
I'd give the videos here a watch, you may find the answer to your problems:
Hello, I built a computer a couple of months ago and I can't get it to work just right. When I play LoL or cs2 sometimes i get good fps but it looks really choppy and not smooth, sometimes i get bad fps.
When I play either apex or warzone i never get bad frames or the problem with good fps but still choppy. But after 10-15 min the game just closes, without an error message.
And my Firefox doesn't play tiktoks or prime video, if I open edge it works without problems. I have no idea if this is linked to the gaming problem but I thought it can't hurt to mention it.
I have had HWmonitor up and the temps are all fine.
Specs:
CPU-AMD Ryzen 7 7800x3d
GPU-AMD Radeon rx 7900 xtx
MB-MSI B650 Gaming plus wifi
PSU-Gigabyte 1000W 80+ gold
RAM-Corsair vengeance ddr5 2x16gb 6000MHz
STORAGE-Kingston snv2s2000g
https://linustechtips.com/topic/1578297-problems-with-new-build/
Specs:
The firefox issue probably is firefox. Re-install firefox and see if that works? What monitor are you running and is it at the maximum refresh rate? Are all your drivers up to date?
My First PC
CPU: Ryzen 5 5600x
Cooler: Asus TUF Gaming LC240
Motherboard: Asus ROG Strix B550-f gaming
RAM: 4x8 GB Corsair Vengeance RS (3200 MHz, CL16)
Storage: 1tb Samsung 980 Pro
Graphics Card: Asus Dual RTX 2060 OC
Case: Deepcool Matrexx 50
Power Supply: Corsair RM650x
Headset: Razer Blackshark V2
Keyboard: Corsair K70 Pro Mini (Speed Silver switches)
Mouse: Razer Viper Mini
Only changes I have made is I sold the 2060 for $235 AUD and bought a Powercolor Red Devil 6700 XT for $400 second hand (it was barely used, think I scored a deal on Ebay with that).
I love Photography (Using a Canon 60D)
Love F1, my favourite team is Ferrari and my favourite driver is Leclerc
I have my main monitor a Benq xl2411P running at 144hz then two side monitors at 60hz.
I believe all the drivers are up to date.
Specs:
Sounds like RAM instability, turn of AMD EXPO and see if the same thing happens, if it does then just manually turn the RAM to 5600 CL30 or something like that and you should be fine.
This is also good info though do this too
alright Ig its been solved
My First PC
CPU: Ryzen 5 5600x
