Budget (including currency): 1000-1200 dollars
Country: Sweden
Games, programs or workloads that it will be used for: Fivem, Development and editing, but also just all kinds of games in general.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I want a fresh build, i currently have a 21:9 3440x1440 ultrawide monitor with a 144hz refresh rate that i use for development, most likely will get myself a 240hz 1920x1080 monitor for regular gaming in the future.
Im looking for some guidence on what parts to choose from, i have played around with parts with a ryzen 5 7600x paired with a radeion rx 7600 8gb, 32gb ram etc, but i just dont know if the stuff im trying out is the "bang for my buck" kinda build. I want as much preformance as i can for this budget.
note : (used to game on a 1660 super paried with a ryzen 5 3400g so anything will def be better then that but i just wanna optimize the value here)
Thank you for anyone that feels like helping out.
https://linustechtips.com/topic/1577145-pc-build-help/
If you already have an AM4 motherboard with a 3400G, then the best "bang for buck" would be to upgrade that CPU to e.g. a 5600 non-X or 5700X3D rather than buying a whole new AM5 PC.
The Ryzen 7600X is fine, but I'd highly recommend you get a GPU much better than that, especially if you ever want to play at 3440x1440 using your primary monitor.
https://linustechtips.com/topic/1577145-pc-build-help/#findComment-16471149
The problem with my old pc is that the PSU fried, and from what i could tell the motherboard SHOULD be fine, but it would just be a lot easier for me personally to start on a completely fresh pc, and buy a new psu for that one and sell it / keep it for GF or Streaming pc
https://linustechtips.com/topic/1577145-pc-build-help/#findComment-16471152
Here is a completely new PC spec for 12K. I had to squeeze the motherboard and memory costs more than I'd like and the NV2 is not a great drive, but I think it is worth it for a better graphics card.
The RX 6800 is 40% faster than the RX 7600, according to TPU's GPU database and it can happily play at 1440p or 1080p, depending on which monitor you want to use.
What kind of development do you do? I'm asking just to establish if you do anything that would prefer/need an nvidia card.
PCPartPicker Part List: https://se.pcpartpicker.com/list/wbdL34
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (kr2204.41 @ Amazon Sweden)
Motherboard: Gigabyte B650M D3HP Micro ATX AM5 Motherboard  (kr1379.00 @ Amazon Sweden)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-5200 CL40 Memory  (kr1099.00 @ Amazon Sweden)
Storage: Kingston NV2 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (kr769.00 @ Amazon Sweden)
Video Card: XFX Speedster SWFT 319 Radeon RX 6800 16 GB Video Card  (kr4717.00 @ Amazon Sweden)
Case: Cooler Master MasterBox MB320L ARGB MicroATX Mini Tower Case  (kr759.00 @ Amazon Sweden)
Power Supply: SeaSonic FOCUS 850 W 80+ Gold Certified Semi-modular ATX Power Supply  (kr1232.00 @ Proshop)
Total: kr12159.41
Generated by PCPartPicker 2024-07-20 19:44 CEST+0200
CPU cooler is included in the CPU box.
Edit: I think the graphics card will be a pretty tight fit in that case.
https://linustechtips.com/topic/1577145-pc-build-help/#findComment-16471234
