cpu possibly too hot?
Solved by MiszS,
Your CPU cooler fans don't spin at all? Are you SURE that the 4 pin fan cable is connected to the "cpu_fan" header? If so, check the fan curve, it may be set to something weird, though idk how could that happen without you doing it
errorcode123_dindin1 ·
Posted in Graphics Cards2 -
Packhunter ·
11
2
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies3 -
Airmack ·
Posted in Graphics Cards1 -
Kyle89 ·
Posted in Troubleshooting2 -
8
5
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
