Take a screenshot of the error list please.
https://linustechtips.com/topic/157579-steam-download-problem/#findComment-2100129
The server closet to you may just be dumb. It will take some time to fix itself. Also, if you are on a network that doesn't allow downloads, you will have to connect to a different connection.
it was working 2 months ago and my network is fine,i can download everything.
https://linustechtips.com/topic/157579-steam-download-problem/#findComment-2104851
