Weird Sound from gpu.
Go to solution Solved by Hinjima,
Just now, kzoxi said:
Yep exactly that it's basically that sound every second or soo. could I have damaged something ? or is it just natural I do have coil whine that I know for sure but it's a completely new sound.
Coilwhine is normal and not dangeorus or harmful in any way.
I highly doubt you damaged the card by adjusting the GPU holder, that would be extremely unlucky.
2 minutes ago, kzoxi said:
Hello thank you for your reply. It's more like a electric shock sound. Started when I  adjusted the GPU holder. It's basically doing it between 2-3 seconds. It's like a clicking sound but electric.
I do hear some clicking at 8-10 seconds on both sound recordings when I turn my volume way up, is this what you mean?
https://linustechtips.com/topic/1575280-weird-sound-from-gpu/#findComment-16454445
https://linustechtips.com/topic/1575280-weird-sound-from-gpu/#findComment-16454447
https://linustechtips.com/topic/1575280-weird-sound-from-gpu/#findComment-16454449
I guess it could be just that I have 0 experience with it. Its also weird that It started after I adjusted it. But I mean if coil whine can make clicking noises like that every second or soo without heavy electric draw then I guess it's just that. Thank you for your time
https://linustechtips.com/topic/1575280-weird-sound-from-gpu/#findComment-16454454
had coil whine on my 6700XT, it was pretty bad when i first got it, actually after a while it started to get quieter. Now it only does it in between loading screens where the FPS spikes to 700+. Completely "Normal" Annoying, but harmless.
Had to make peace with mine, but found a middle ground.
Cheers
Current built PCs:
1: XFX DD  AMD R7 260x / AMD FX-6300 4.7ghz OC /  MSI 970A Krait edition mobo / Deepcool captain 120 AIO cooler / 10gb of 1866 ram???? / 750W evga psu  / 1TB Seagate 'Cuda + 16GB SSD /  packed into a Bitfenix Shadow  window
2: Intel G3258 3.5 GHZ OC / G1 gaming 4gb GTX960 / 8GB of Ram / 128GB A-data ssd/ misc gigabyte mobo / Alpine Pro rev2.0 cooler / 500W Seasonic PSU / in a Bitfenix Pandora Window
3: AMD A6-7400K 3.8 GHZ OC / Misc AM2+ Gigabyte mobo / Cooler master Hyper T2 Cooler / 1 TB Seagate 'Cuda / 8GB 1866 corsair vengeance pro RAM / XFX 500W psu / in a cougar spike case
4: Intel G3258 oc 4ghz / Random MSI mobo / 1TB seagate 'Cuda / Cooler master hyper T-4 / 8GB Fury X ram / 4GB Club 3D R9 380 / 500W EVGA psu / locked up in a thermaltake versa N21 window
5: AMD FX-6300 4.1OC / Cooler master T4 cooler / MSI 970A gaming motherboard / 1TB Western digital blue / 8GB Hyper X Ram / 500W Thermaltake PSU / 2GB XFX DD R9 280 / Bitfenix Nova window case
The odd laptop: Asus ROG GL552-VW / intel i7 skylake / GTX 960M 2GB / 1TB toshiba HDD / 128 GB A-data M.2 SSD
https://linustechtips.com/topic/1575280-weird-sound-from-gpu/#findComment-16455576
