Hi, I'm worried about my PC because its been constantly shutting down(avg. like 4 times/week probably) due to power outage. I have Deepcool PM650D with AMD 6750XT.
Looking for UPS options which make my PC be active for 10 mins (not any longer than that) after power outage so that i can properly shut it down and also be budget friendly. I saw some article about this Active PFC in PSU and got confused.
Suggest some UPS. And also this sudden shutdown of my PC due to power outage do any damage to my PC ?
https://linustechtips.com/topic/1575053-ups-for-my-pc/
What country are you in, and what's your budget?
You can forget the tiny, cheap models no matter where you are. You likely won't get the runtime you want out of those.
It's more dangerous for your data (corruption) than your hardware. The surge from power suddenly coming back is a bigger concern for your hardware, but that's why you use a quality surge protector.
https://linustechtips.com/topic/1575053-ups-for-my-pc/#findComment-16452303
I'm from India. Budget within 10k rupees, better if its less pricey. I'm happy with a UPS which hold my PC for even 5 mins because mostly i will be gaming or watching movies when the power goes off. So i just need a UPS to shutdown my PC safely.
https://linustechtips.com/topic/1575053-ups-for-my-pc/#findComment-16452316
