7 minutes ago, b_12600 said:
i found out that my ram doesnt work anymore since i also tried in another pc so i bought new rams should it fix the error ?
Have you tried the new ram yet? It could also be that the motherboard ram slots are broken. Try using only one ram stick in slot A2 only
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1570503-red-dram-light/#findComment-16411819
well the new ram coming in a week and i even tried to use 1 stick but still doenst work and tried also in another pc but i think its the ram thats faulty
https://linustechtips.com/topic/1570503-red-dram-light/#findComment-16411820
So the PC doesn't boot with one or two sticks in? Did you try each stick in slot A2? Did you use the correct slots? (i.e. for both use the second to the right and the furthest to the right)
Is it only the DRAM light that lights on when you turn it on?
Does your ram have any rgb?
Total: £1040.95
https://linustechtips.com/topic/1570503-red-dram-light/#findComment-16411826
i tried both sticks in every slots and theres only the dram lights and my pc does have an rgb
https://linustechtips.com/topic/1570503-red-dram-light/#findComment-16411827
does that rgb light up when you turn on the pc? Also is this rgb on the ram or motherboard?
What're your system specs?
Total: £1040.95
https://linustechtips.com/topic/1570503-red-dram-light/#findComment-16411829
it does light up and the rgb isnt in neither of them its just the case and also the specs are ryzen 7 1700 rtx 2060 super 1tb ssd 2tb hdd b350 pc mate
https://linustechtips.com/topic/1570503-red-dram-light/#findComment-16411830
Try and wait for the new ram to arrive and try that
Did you try only one in A2 and only B2?
has this only happened recently or is it a newly bought computer and this is the first time you've turned it on?
Edited by filpo
Total: £1040.95
https://linustechtips.com/topic/1570503-red-dram-light/#findComment-16411836
Just now, b_12600 said:
yea
Is this a problem that occurred out of the blue and the pc was working fine before?
if so, have you done anything with the pc before this problem arose?
Total: £1040.95
https://linustechtips.com/topic/1570503-red-dram-light/#findComment-16411839
it worked great there wasnt a problem at all
Did you do anything before this problem arose? Like tinker with the pc at all?
Total: £1040.95
https://linustechtips.com/topic/1570503-red-dram-light/#findComment-16411845
Since the ram doesn't work even when you put it in another PC, sounds like it is faulty.
Usually ram has a lifetime warranty. Did you buy this ram new?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1570503-red-dram-light/#findComment-16411963
3 hours ago, b_12600 said:
i bought it used
That's unfortunate, most ram warranty doesn't transfer to secondhand although you could reach out to the manufacturer with the serial number to see if they honor it
Primary PC:
PSU tier list
https://linustechtips.com/topic/1570503-red-dram-light/#findComment-16412667
