Budget (including currency): 1300usd with tax
Country: Poland
Games, programs or workloads that it will be used for: Sketchup, V-Ray, 3DSMAX, Autocad, Photoshop
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at):
Configuration I thought about:
* MSI PRO B760M-A WIFI DDR5
* Intel Core i7-14700
* Lexar 2TB M.2 PCIe Gen4 NVMe NM790
* Kingston FURY 64GB (2x32GB) 5600MHz CL36 Beast Black EXPO
* Thermaltake Litepower II Black 650W
* Kolink Stronghold M Black
Hi, I need a computer for work. I do home interior designing, create models in sketchup and render them in vray. This will be my first build and there is a lot of opinions on the Internet, but most of them are for gaming computers.
* Is the configuration I thought of optimal or should I go amd?
* Do I need K processor? I won't do overclocking, but K processors appears to have higher clock speeds.
* Is stock cooler enough or should I buy better air cooler, AIO?
* I thought of not buying dedicated GPU as most of my workload is on cpu and I could add GPU later.
I would really appreciate some help. Thanks.
https://linustechtips.com/topic/1567645-first-computer-build-for-work/
Not really for intensive workloads, if the budget allows it then definitely invest in a good air cooler
Console.WriteLine("Hello World!");
For home interior design I wouldn’t imagine you’d need much.  What do other people who use this software usually use for work at your level?  A used gaming PC might be able to handle your workload effortlessly .  Something with a 1070 should be under $300.
I edit the shit out of my posts.  Refresh before you respond.
  • The memory kit is sub-optimal as it is intended for AMD CPU. Select a kit that includes XMP profiles. Ideally DDR5-6000 CL30. The PSU is a bad choice. See https://cultists.network/140/psu-tier-list/ for options. Mesh front cases tend to have better airflow. This may lead to quieter and more efficient operation.
  • A non-K CPU is fine. But check pricing. In some markets the i7-14700K is actually less expensive (although one has to add a cooler).
  • Stock cooler should be fine although if may make the system loud at times. It may also hamper performance when the CPU is fully loaded for longer periods.
  • Even an inexpensive GPU can improve performance. Photoshop may use an Nvidia GPU to accelerate certain functions. In general a GPU will improve display performance making the system seem more responsive.
