I suppose you're talking about the yes legend game, based on the og Lithtech 2005 engine. Can we get full specs? I recall it was something that happened to me as well during the much more golden era of my life. Was mostly a harddrive thing. Most of it went away when I rolled it over to SSDs...
https://linustechtips.com/topic/1567590-fear-lagging-issue/#findComment-16387606
Have you checked the temps on the GPU and CPU? Given that the build is on the more 'experienced' side, maybe the CPU or GPU needs some repasting.
EDIT: I just realized those components are mobile, so we are talking about a laptop. Is it plugged in? Powerplan set to performance? Fans still running and thermals ok?
https://linustechtips.com/topic/1567590-fear-lagging-issue/#findComment-16388698
There is no thermal problem in laptop. Both CPU and GPU stays at below 70°C and laptop runs at performance mode(laptop plugged to adapter of course)
https://linustechtips.com/topic/1567590-fear-lagging-issue/#findComment-16389171
Are you by chance using a Logitech mouse, or a Logitech peripheral? I recall that there was an issue with Logitech driver having some sort of conflict with the game. Even I, when I was playing the game when it was first launched, had a powerful rig at the time but also had a logitech  mouse and/or keyboard, I had bad framerate dropping to single figure.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/1567590-fear-lagging-issue/#findComment-16390223
No. My keyboard/mouse is sades
https://linustechtips.com/topic/1567590-fear-lagging-issue/#findComment-16390311
1 hour ago, Motifator said:
This probably happens due to the over all setup being just... old. F.E.A.R used to be hefty on setups of that era, and the fact that this is such an antic laptop with a HDD adds up.
Try with an SSD on the game.
SSD is inside laptop and game located in SSD
https://linustechtips.com/topic/1567590-fear-lagging-issue/#findComment-16390679
