ello while ilde with discord open ,chrome but nothing actually playing with tabs in active at chrome my temps seem to be high the pic below is what me temps are while the situation i just mentioned is occuring im new to built pcs still as this is the first one ive built myself specs are as follows
i7 12700kf
Nivida rtx 3060 ti
 air cooler: Noctua NH-U12A
im tryna figure this out soon bc im poor atm i got lucky to be able to buy the parts for this pc an i dont know what to do as ive said these temps are happening while discords open (im not in a call or anything literally just have it open an chrome of which im doing literally nothing on an steam in he background but nothings downloading ,no games are updating / running so im not seeing a reason for temps to go up pic below is exactly but hardware monitor was showing right before i typed this up the value catagory is whats currently happening the min is the lowest its gotten to  the max is the highest its gotten to an thats underload via spike its not consistently stay at 91 while im gaming it stays 70-80c while im gaming
https://linustechtips.com/topic/1566932-are-these-temps-normal/
i7 12700kf
Nivida rtx 3060 ti
Temps seem a little hot but no where near anything to worry about, open task manager and sort by gpu to see what is using your GPU the most, also, a lot of GPUs have a zero rpm mode which means they wont spin fans at all til X temperature meaning even when idle, so long as its not doing a ton fans wont spin but heatsink will slowly increase in heat
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1566932-are-these-temps-normal/#findComment-16382763
its usage is at 1% also the hotspot temp is now 51c
https://linustechtips.com/topic/1566932-are-these-temps-normal/#findComment-16382764
GPU temps without seeing usage and clockspeed isn't helpful. Expand those sections. Fans speed too, while you're at it.
(better yet use HWiNFO, HWMonitor is known to give false readings, it should always be avoided)
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1566932-are-these-temps-normal/#findComment-16382792
i7 12700kf
Nivida rtx 3060 ti
Don't see anything unusual, a 12700K full blast with a NH-D12 can reach 90C+
GPU temps look fine as well
https://linustechtips.com/topic/1566932-are-these-temps-normal/#findComment-16382834
 I completely missed the cpu max, good find 😂
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1566932-are-these-temps-normal/#findComment-16382837
https://linustechtips.com/topic/1566932-are-these-temps-normal/#findComment-16382923
6 minutes ago, WolfOfValahalla said:
Assuming the clockspeed (hidden in that screenshot) is at or thereabouts 210Mhz the GPU is idle and with the fans off, the temps look normal.
https://linustechtips.com/topic/1566932-are-these-temps-normal/#findComment-16382929
this is what hwinfo is saying
https://linustechtips.com/topic/1566932-are-these-temps-normal/#findComment-16382947
