Specs:
4060
PSU: MPG A650GF
CPU: 14700KF
MB: MSI Z690-P DDR4
RAM: 2x16
SSD: M.2 + SATA 3 drives. One each.
Cooled by peerless assasin SE
Recently CPU died and I got it replaced. Now I slotted the new one in and PC won't boot showing white VGA LED when powered on. GPU spins to life when power button pressed along with CPU cooler and case fans. Monitor shows no signal at all. I dont know what to do...
I have tried:
- Reinstalling GPU 5x
- Checking all PSU cables if they are connected well 4x
- Resetting CMOS
- Turning on without any SSDs inserted
- Using both HDMI and display port cables from monitor to GPU
https://linustechtips.com/topic/1565486-white-vga-light/
Sounds like you tried a lot of things already!
So your CPU died right? Are you 100% sure that it was the CPU that died, it's possible of course but they are along with RAM one of the least likely to fail from my experience.
In any case, you're trying to use 14700KF on a MSI Z690-P DDR4?
You might need to do a BIOS update from what I'm reading from other people. You are using DDR4 RAM right?
>> Please consider tagging me (with a @) or quoting my reply so I can more easily get back at you! <<
Always happy to help!! 🤠
https://linustechtips.com/topic/1565486-white-vga-light/#findComment-16372216
Using DDR4. DRAM LED is not on and I tried booting with each stick individually to see if one is dead but nothing changed
https://linustechtips.com/topic/1565486-white-vga-light/#findComment-16372489
I see, then a BIOS update might be the way to go here
https://linustechtips.com/topic/1565486-white-vga-light/#findComment-16372863
