Build help
Go to solution Solved by Why_Me,
PCPartPicker Part List
CPU: *AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($189.99 @ Walmart)
CPU Cooler: *Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: *MSI PRO B650-S WIFI ATX AM5 Motherboard  ($159.99 @ Newegg)
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($94.97 @ Amazon)
Storage: *ADATA Legend 800 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($108.99 @ Amazon)
Video Card: *Sapphire PULSE Radeon RX 7800 XT 16 GB Video Card  ($489.99 @ Newegg)
Case: *MagniumGear Neo Air 2 ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Monitor: *Gigabyte GS27Q 27.0" 2560 x 1440 170 Hz Monitor  ($179.99 @ Newegg)
Total: $1417.80
Generated by PCPartPicker 2024-03-24 15:26 EDT-0400
Budget (including currency): 1500$us
Country: USA
Games, programs or workloads that it will be used for: AAA titles, competitive MMO
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):will need peripherals and refresh rate 140 or higher resolution 1440p
Any and all help would be greatly appreciated and if I could save money and not give up performance not really much mind the aesthetics of the build just want the most bang for the buck performance for gaming
https://linustechtips.com/topic/1564098-build-help/
Total: $1417.80
https://linustechtips.com/topic/1564098-build-help/#findComment-16362032
