11 Pin USB header?
Go to solution Solved by somethingawsome,
According to this, I think you just shift the connection over so you dont use the two left most pins. The extra two pins are just ground apparently!
http://forums.lenovo.com/t5/A-M-and-Edge-Series-ThinkCentre/ThinkCentre-A60-front-panels-power-audio-and-USB-pinout/td-p/190651
Hi Guys
I am rebuilding my old pc in a new case and i have discovered that i have an 11 pin USB 2.0 header.I have never seen one of these, could someone please help me out or tell me where I can get an adapter or something so I can plug a 9 pin into it?
Thanks!
Regards,
Ben Cooper,
CEO
https://linustechtips.com/topic/156197-11-pin-usb-header/
Can you take a picture of it?
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/156197-11-pin-usb-header/#findComment-2082156
wow 11 pin usb header is so rare a search this post is in the front page of Google results
I would suggest if this http://en.community.dell.com/support-forums/desktop/f/3514/t/19380581.aspx is true and the additional 2 pins are for power then  you could bend them out the way and use the normal 9.  but it looks like a normal 9 pin header will still fit on top (with no pin bending).
bit fist i would make sure it is usb and that the you don't have a warrant or anything to worry about losing.  what is the board make/model.
https://linustechtips.com/topic/156197-11-pin-usb-header/#findComment-2083055
Lift Large and Prosper!
https://linustechtips.com/topic/156197-11-pin-usb-header/#findComment-2084062
  • 8 years later...
  • 10 months later...
