Resize bar will not work
Solved by 191x7,
4 minutes ago, Christopher_829 said:Secure Boot is off
I am using windows 11I am using UEFI boot
CSM is on
I have some MBR drives but windows is on a GPT drive
My CPU is a Intel core I5 10400f
Sorry for late reply I had to go check all that stuff
Well, you have to fix this.
Turn Safe boot in msconfig ON (so your system boots into safe mode the next reboot).
Reboot. Turn Secure Boot ON, turn Compatibility Support Module OFF. Save the settings.
Boot into Windows (safe mode). Turn Safe boot OFF. Reboot.
Report back.
