First PC Build Advice
Solved by Hellowpplz,
6 minutes ago, Raindrop788 said:The only issue i have with buying used is that this will be my first PC build and would like the security of buying new, to avoid any issues with possible faulty parts, as my budget is so low if i buy used with zero experience and idea of what to look for and get something faulty, I just wouldn't end up with anything but an incomplete pc that ill be unable to finish for quite some time.
tbf if you get sent the wrong thing or it's damaged when the seller didn't disclose that, you can keep it and get a refund if you buy off of ebay. As long as your 100% sure it's fine at least as of the listing name, pictures, and the description. Post findings so that me or @PDifolco or anyone else can look at it.
