Specs:
Motherboard: MSI B760 GAMING PLUS WIFI
CPU: Intel Core i5-12600K 10C/16T 4.9GHz LGA1700
GPU: MSI GeForce RTX 3060 VENTUS 2X 12G OC
RAM: CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL36 Intel XMP iCUE Compatible
PSU: MSI MAG A750GL PCIE5 Power Supply Unit, 750W, 80 Plus Gold
CPU Cooler: DeepCool AK500
M.2 SSD: Crucial P3 1TB M.2 PCIe Gen3
I have plugged in my motherboard 24 pin ATX, CPU PWR 1, and GPU PCIE into the PSU.
When I turn on the system it goes between red CPU and orange DRAM LEDs before staying on a solid yellow DRAM EZ debug LED.
I have tried reseating the CPU, different RAM sticks, different RAM slots. I don't have a second DDR5-Compatible motherboard to test with, or a second modular PSU.
Any ideas?
https://linustechtips.com/topic/1560058-new-computer-not-posting-dram-led/
30 minutes ago, Jay K. said:
I waited ~45 minutes
Only other thing I'm aware of that can cause boot issues is a cooler mount that is uneven or too tight/too loose.
Did you try the onboard with the graphics card pulled? Preferably using HDMI.
