6 minutes ago, gustix said:
Hey guys, so i have a big problem when gaming, i have a big diffrence of cpu and gpu usage, i have heard that its not good having your cpu goin full speed and your gpu like 10-20% , idontknow how to fix thiz if you have a idea could you share?;Dd
What is your PC specifications?  What is not good about it is just that you GPU might be underperforming, nothing dangerous or bad will happen having your CPU at 100% as long as temperatures are good.
https://linustechtips.com/topic/1559047-neeed-help/#findComment-16325951
My cpu is i5 4430
and gpu gtx 1660
, idk what is underperforming but i would want to fix that:Dd
https://linustechtips.com/topic/1559047-neeed-help/#findComment-16325961
Just now, gustix said:
My cpu is i5 4430
and gpu gtx 1660
Your CPU is very old and very slow by today's standards and is stopping your graphics card from running faster as the i5-4430 is holding it back.
The only way to fix this would be to get a faster CPU.
Nothing bad is happening in the sense that nothing is going to break and having a CPU run at 100% is completely safe.
https://linustechtips.com/topic/1559047-neeed-help/#findComment-16325963
Okaai thankz for ur help, i will have that in mind
https://linustechtips.com/topic/1559047-neeed-help/#findComment-16325965
