Problem with older iMac
Solved by Dillpickle23422,
2 minutes ago, Lorixxxx said:Thanks alot , i will try to find a browser that supports that os
Yep! No problem. As for discord, if you do find a browser that supports this mac, I would probably just see if the browser version (not the actual app) works. The Discord app's minimum version of MacOS is 10.15.
