So i have a gt 1030(4GB) i tried playing warzone with amd fsr 3 performance with frame gen on
but whenever i am in lobby it goes black and ui doesnt show up
same result everything black in lockdown quads
if in game i switch to fsr3 screen goes black only sound comes
is it my problem or a general problem?
how to fix this pls help
(also i know my gpu is trash so pls answer question only)
https://linustechtips.com/topic/1554590-amd-fsr3-problem-warzone/
Firstly 1030 is too slow for Warzone, at least states by requirements. Frame gen says even GTX (not GT) 1000 series cards is too old to support full so it won't work officially, likely more bugs and does the GT 1030 even get NVIDIA drivers anymore? Drivers themselves might just be too old to play the game.
Just be time to upgrade as I don't think there's a "supported" workaround.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
4 minutes ago, venomtail said:
Firstly 1030 is too slow for Warzone, at least states by requirements. Frame gen says even GTX (not GT) 1000 series cards is too old to support it so it won't work officially, likely more bugs and does the GT 1030 even get NVIDIA drivers anymore? Drivers themselves might just be too old to play the game.
yes i get nvidia game ready drivers update but what is causing the black screen problem also i bought it in 2022 when gpu prices were super high and i wont get a new one unless i go to a good college in few month
then i guess you better study(?)
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
5 minutes ago, ITADORISENSEI said:
you are right 😞
or just don't use fsr3 and lower your resolution and graphics settings
Dude's 1030 barely break 30fps at like 720p with tons of 1% lows.
20 minutes ago, ITADORISENSEI said:
i get 25 fps using nis at 75 at performance since i heard so much about fsr 3 i was just looking to use it to push my fps to 30 at least
The 1030 is a bit of a lost cause. I'd not put effort into making it work as it's just too old. Get a used GTX980TI for something like $50 at most. Should double the framerate if not even tripple it without FSR.
