Posted May 21, 2014 So I am going to build myself a computer in the nearst future and I think I need some help with the part picking. The build is on a 1100$ Budget and its main focus is gaming. Not Ultra gaming, but around HIGH settings. I am not focusing at overclocking as this is my first build. Here is the Partlist: http://pcpartpicker.com/user/Joackim/saved/4L63 For people who are too lazy to click the link, here is the list once again: CPU : Intel Core i5 4440 GPU: MSI GTX 760 TF 2GB PhysX RAM: Kingston HyperX 8GB DDR3 1600MHz MOBO: MSI H97 Guard Pro LGA 1150 SSD/HDD: Samsung EVO 840 120GB/Seagate Barracuda 1TB PSU: Corair CX 600M 600W CPUCOOLER: Cooler Master Hyper 212 EVO OP: ASUS DRW-F1ST OS: Windows 7 Home Prem. Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2014 Spend more on processor and spend less on motherboard. Get cheapest 2x4 heatsinked branded ram. Get seasonic or xfx psu, 400watts or more is ok. Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/#findComment-2072082 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2014 If you aren't overclocking the stock cooler is fine, no need for that 212 EVO. If that H97 board is more expensive than say a H87, don't get it. Just get H87. You'd be fine on a Corsair CX430watt PSU, which is only like $40. BUT, it is non-modular. Why Windows 7? Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/#findComment-2072089 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2014 Looks good. Potatoes are good for your nostrils. Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/#findComment-2072091 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2014 Author If you aren't overclocking the stock cooler is fine, no need for that 212 EVO. If that H97 board is more expensive than say a H87, don't get it. Just get H87. You'd be fine on a Corsair CX430watt PSU, which is only like $40. BUT, it is non-modular. Why Windows 7? I prefer windows 7 over windows 8, and here in Norway they are priced the same, and Im going with 600W because im hoping to upgrade in the future without having to swap out everything. I chose the 212 EVO because i've had a computer with the stock cooler and makes alot of noise. Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/#findComment-2072106 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2014 PCPartPicker part list / Price breakdown by merchant / BenchmarksCPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($188.98 @ SuperBiiz)CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.94 @ OutletPC)Motherboard: MSI H97 Guard-Pro ATX LGA1150 Motherboard ($99.99 @ Amazon)Memory: Kingston HyperX 8GB (4 x 2GB) DDR3-1600 Memory ($134.66 @ Amazon)Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk ($89.99 @ B&H)Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Amazon)Video Card: MSI GeForce GTX 760 2GB TWIN FROZR Video Card ($239.99 @ Amazon)Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case ($99.99 @ Micro Center)Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ Newegg)Optical Drive: Asus DRW-24F1ST DVD/CD Writer ($14.99 @ Newegg)Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ OutletPC)Total: $1098.49(Prices include shipping, taxes, and discounts when available.)(Generated by PCPartPicker 2014-05-21 14:59 EDT-0400) This is what OP listed. Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/#findComment-2072111 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2014 Everything has been covered pretty much... So I spelt something wrong in my post... I don't care I don't read through what I write and I type very quickly. Intel 3770k stock, MSI Z77A-GD65, MSI GTX 760, Corsair Vengence DDR3 1600Mhz 16Gb, Corsair RM 550W, Samsung 830 256Gb, some random hdds. Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/#findComment-2072139 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2014 Author Spend more on processor and spend less on motherboard. Get cheapest 2x4 heatsinked branded ram. Get seasonic or xfx psu, 400watts or more is ok. So, ill go for a i5 4570 and MSI B85-G43 instead? I know B85 isnt that great. Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/#findComment-2072146 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2014 For a gaming rig, a GPU > CPU usually. http://pcpartpicker.com/p/3Omgv Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/#findComment-2072151 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2014 So, ill go for a i5 4570 and MSI B85-G43 instead? I know B85 isnt that great. Its pretty good, depends what are your needs and what features you want. In fact, even h81 would do. For a gaming rig, a GPU > CPU usually. http://pcpartpicker.com/p/3Omgv this is good, dunno about PSU, but looks solid. however i wouldnt recommend overclocking on this mobo at all. Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/#findComment-2072192 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2014 this is good, dunno about PSU, but looks solid I just chose a PSU from a brand I "trust." Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/#findComment-2072198 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2014 Author @Manny Calavera Ofc I wont overclock, i am good with 3.6 GHz, im atm used to 2.1 with this laptop soo... Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/#findComment-2072204 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2014 I just chose a PSU from a brand I "trust." I trust in both seasonic and nzxt Good choice of psu, i recommend ! @Manny Calavera Ofc I wont overclock, i am good with 3.6 GHz, im atm used to 2.1 with this laptop soo... I am more worried on single core performance of this processor. But in the long run, its ok processor, even at stock. Just dont raise voltages. Or you could get ud3p from gigabyte and dont worry at all. Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/#findComment-2072217 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2014 Could be cheaper: http://pcpartpicker.com/p/3OmMG If you ever need help with a build, read the following before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/Also, make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them. Link to comment https://linustechtips.com/topic/155439-building-a-computer-soon-need-help/#findComment-2072224 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
