Budget (including currency): £2000 GBP roughly thought this is slightly flexible
Country: UK
Games, programs or workloads that it will be used for: Rocket League, Destiny 2, BG3, Fortnite as well as some basic game dev and other development
Looking to build a PC later this year as I am going back into education to start a degree in software engineering. As I have not owned a PC in nearly 15 years, I was hoping for a sanity check/any tips that might be helpful. I don't have anything currently so will need everything new. Planning to forgo a monitor at first as I have an LG C1 OLED 65" which can be used for the first few months.
Basic specs I have been looking at:
CPU: Intel 15-13600K
Mobo: Will decide at the time, probably B760, will decide exact model based on pricing at the time
Memory: 32GB DDR5 6400MT+, looking for CL 36 or below
Cooling: Noctua NH-D15
Storage: 2TB Gen 4.0 M.2, have a Crucial P5 in my PS5 so something similar
Case: Fractal Design North TG Black
GPU: RTX 4080 Super
Power Supply: 1000W GOLD, been looking at seasonic and corsair
Will be looking to game at 1440p mostly but some games will be played in 4K on the TV. Monitor selection will depend on pricing at the time of purchase but currently looking at the new 27" 360Hz OLED from alienware which is only 1440p but should be excellent for pretty much any use case.
Any advice or anything would be much appreciated.
https://linustechtips.com/topic/1553614-first-pc/
Country: UK
GPU: RTX 4080 Super
Hello... Looking over your list it looks quite good, however I did have to make some changes.
1. If you are going to be doing anything more than just Gaming then I suggest a Core i7. It will give you the power you need to Play your Games and do your Development at the same time without the CPU running into any issues. Plus more Cores and Threads will help also.
2. The Noctua NH-D15 "WAS" the best Cooler. There are several other options now that are just as good for a much lower price. Plus the NH-D15 does not come with the new LGA 1700 Mounting Bracket for the Motherboard. I added a Cooler that performs just as good if not better in some ways for 2/3 less in price. The Thermalright Phantom Spirit 120 SE is so good that it would be a Sin not to use it. Even though this Cooler is one of the best Air Coolers I still would recommend a 360mm AIO like the Thermalright Frozen Notte 360 Black ARGB.
3. I don't think you should be getting the Fractal Design North Case. For it's price it's just not worth it. There are plenty of other Cases that are much better that offer high Airflow and also have lots of Fans. The Case this I picked has 4 ARGB Fans in it and has a Digital Readout for CPU & GPU Temps and Speeds.
4. I added a CPU Thermal Block. Since the Intel 13th & 14th Gen CPUs get really hot the Block will help lower your CPU Temps from anywhere from 10-25 Degrees.
If you have any questions please let me know. I would also like to know what you think of my List.
I have been building PCs for over 30 years so if you have any questions please ask. For future communication I use Discord for much faster response times as I have it open 24/7. Here is my Discord: Wizardsnapper#2772 I am also available if you need help before, during, or after the Build process on Discord through Voice or Video Chat. I can be with you while you build your new PC if you need me to be.
https://uk.pcpartpicker.com/list/m4YfkJ
CPU: Intel Core i7-13700K 3.4 GHz 16-Core Processor  (£377.54 @ Amazon UK)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (£42.92 @ Amazon UK)
Thermal Compound: Thermal Grizzly Aeronaut 3.9 g Thermal Paste  (£12.49 @ Amazon UK)
Motherboard: MSI MAG B760 TOMAHAWK WIFI ATX LGA1700 Motherboard  (£179.99 @ Ebuyer)
Memory: ADATA XPG LANCER RGB 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory  (£120.91 @ NeoComputers)
Storage: ADATA XPG GAMMIX S70 Blade 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£114.99 @ AWD-IT)
Video Card: MSI GAMING X SLIM GeForce RTX 4080 SUPER 16 GB Video Card  (£1065.99 @ Ebuyer)
Case: Deepcool CH560 DIGITAL ATX Mid Tower Case  (£99.00 @ Computer Orbit)
Power Supply: Corsair RM1000e (2023) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (£144.89 @ NeoComputers)
Custom: Thermal Grizzly Intel 12th Gen. CPU Contact Frame  (£60.20 @ Amazon UK)
Total: £2218.92
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
https://linustechtips.com/topic/1553614-first-pc/#findComment-16290033
PCPartPicker Part List
CPU: *Intel Core i5-13600KF 3.5 GHz 14-Core Processor  (£276.97 @ Amazon UK)
CPU Cooler: *Deepcool AK620 68.99 CFM CPU Cooler  (£54.12 @ NeoComputers)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  (£149.00 @ Computer Orbit)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£108.91 @ Amazon UK)
Storage: *Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£129.99 @ Ebuyer)
Case: *Fractal Design North ATX Mid Tower Case  (£134.99 @ Amazon UK)
Power Supply: *Corsair RM1000e (2023) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (£144.89 @ NeoComputers)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan  (£9.09 @ Amazon UK)
Total: £1007.96
Generated by PCPartPicker 2024-01-19 22:17 GMT+0000
https://linustechtips.com/topic/1553614-first-pc/#findComment-16290151
C32 for 6400, C30/28 for lower speed. But yeah beyond that everything is on the money, look into @Why_Me build.
You also might wanna eye on the locked 14700 thatll drop anytime soon. Thatll be a good drop in pre purchase upgrade and most B760 board that is good for the 13700 should be good on that CPU too.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1553614-first-pc/#findComment-16290364
Thanks guys, 13700K/14700 might be a better shout for the extra cores.
I was mainly looking to stay air cooled due to potential reliability concerns with AIO coolers but if anyone has any real experience they could share it would be much appreciated.
As for the case, the choice was made mainly as I love the design of the Fractal North while it might not be the most optimal. Obviously I would change this if I found I had a real need but from some research there have been others running a similar config in the North with no issues so far.
Would you recommend a reseller key for Windows? Is there any downside to a resold key other than it being single use?
https://linustechtips.com/topic/1553614-first-pc/#findComment-16292177
