Those of you with Reference Nvidia cards, be it a reference design 10 series, 20 series, 30 or 40. Do you regret the purchase?
Those with Reference 20 series or 30 series, are you finding that they are aging faster than say your friends with non reference versions?
I am curious as I am going to be purchasing a Super 40 series card, and curious if I should pull the trigger on a reference card and save some $$ or just go with a Gigabyte or PNY. I am staying far away from Asus. I know all brands suffer from. Coil wine, but I hear Asus and MSI are on the top of the list.
https://linustechtips.com/topic/1553244-to-those-with-reference-cards/
All cards whether reference or not perform within the same sort of tier as each other , Especially 40 series reference cards which tend to be built just as well as the AIB cards.
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
