Help with upgrading PSU
6 minutes ago, Zatask said:I'm looking to upgrade my GPU to an Nvidia RTX 3060 12GB in the near future. Currently I'm running an Intel Core i5 10400f, 16GB of RAM and an Nvidia GTX 1650 with a Corsair CV550 PSU.
Everywhere I check about the 3060's power requirements it suggests more than 600 Watts which would mean I'd have to upgrade my PSU when I do my GPU, yet I also used Cooler Master's PSU calculator and it said I'd only need 330 Watts which seems insane, so I'd rather just ask here before I blow something up.
Thanks in advance for the advice![]()
The 10400f is a 65w CPU at max load and the 3060 12GB draws a max of 170w under full load.
A 550w PSU is enough for this setup without being dangerous.
Howeeever.. The CV550 is not a particularly good PSU and should be swapped out if possible.
330w from the Cooler Master PSU Calculator is actually quite close to correct.
65w+170w is 235 + 60-80w for the rest of the system. This is under 100% load on all parts of course.
