2nd Monitors display issue
Hi,
My second Monitor display is detected as non-pnp and I don't know why.
Here is my configuration:
DisplayPort to VGA
Windows 10 version 1809
Motherboard Intel Apollo lake.
Integrated GPU Intel HD 505 with Intel Driver 31.0.101.2125
VGA cable Pin15 not connected
I have the exact same monitor connected, the first one is recognaized as PNP but not the second one.
when I switch from duplicate to extended, the second monitor is black screen ( resolution or active signal not ok), expecting resolution 1920x1080
note that I was previously with old configuration WIndows 10 version 1607 and HD 505 driver ver 23.20.16.4982.  and did face the issue before.
Thanks for your help
https://linustechtips.com/topic/1548921-2nd-monitors-display-issue/
