Ones sold by amazon and ones sold by Fennic INC
CPU: Ryzen 7 9800x3D
CPU Cooler: Arctic Liquid Freezer III Pro 360
Motherboard: Asus Tuf b650e-e wifi
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory
Storage: TEAMGROUP T-Force Cardea Z44L 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Video Card: Sapphire Pulse 9070
Case: Phanteks Eclipse G360A ATX Mid Tower Case
Power Supply: Super Flower Leadex III Gold UP 850 WW
Monitor: LG 27GN800-B 27.0" 2560 x 1440 144 Hz Monitor
https://linustechtips.com/topic/1548338-difference-in-these-cards/
That "AGP" interface is incorrect - it is an old graphics card interface that predates PCI-Express. I would gather that the only difference about these cards is perhaps the clock speeds, but the difference is minimal at best. The SWFT might be a bigger card, but I do not think it is worth the extra cost.
it is what it is
Main PC
AMD Ryzen 7 7800X3D | Gigabyte B650 Gaming X AX | 32GB 2x16 DDR5-6000MHz | RX 6800 FE | 2x 1TB SSDs | Windows 10 Enterprise LTSC 2021
NAS
Intel Core i3-7100 | ASUS Z270M Prime Plus | 16GB 2x8 DDR4 | 256GB Samsung SSD | 4x2TB WD Blue HDDs | TrueNAS Scale
Windows XP Gaming Rig
Intel Xeon E5-2620 | 32GB 8x4 DDR3-1600MHz | ASUS P9X79 LE | GTX 960 | 500GB HDD | Windows XP Professional
Yeah, I was reading the reviews on the card and the cheaper one, people were having problems with the card like it was running hot and it was giving errors.
Also, the 400$ one arrives before Christmas, and I would like to have it before Christmas or on Christmas day. Or a little after words. The cheaper one arrives in January. My current PC is dying on me.
Seems like you have good rationale to pull the trigger on the $400 card. I'll say that as an RX 6800 owner myself, it is a very good card and you will have no issues with it (knocking on wood).
it is what it is
Main PC
NAS
What 6800 do you have? Also, I was looking to step down to a 6750xt or a 4060ti for price reasons. But all the cards I look at the poor reviews are really bad. I am concerned that if I dont spend a lot of money on a good card it will not be good. I've saved up for a long time for this and if its bad I dont know what to do.
I have the founder's edition card, and use it for ultrawide 1440p gaming. Luckily for you, most card manufacturers have RMA processes so if a card does end up nonfunctional, you can return it. Don't let the poor reviews sway you - every product will have poor reviews. Use your gut and buy something with a good return / RMA policy.
it is what it is
Main PC
NAS
